Beo5 Config Tool - how to remove a zone
I toyed around with my Beo5 Config Tool and accidentally added a zone which I do not really need. Actually I need just one zone, and that one is called "Main". Would anyone know how to remove the 2nd zone I added but do not need? Thank you very much, Stefan
Https://Beoworld.Org/Wp Content/Uploads/2025/01/Beotime 1 Https://Beoworld.Org/Wp Content/Uploads/2025/01/Beotime 1
Https://Beoworld.Org/Wp Content/Uploads/2025/01/Beosound 9000 1 Https://Beoworld.Org/Wp Content/Uploads/2025/01/Beosound 9000 1
Https://Beoworld.Org/Wp Content/Uploads/2025/01/Beoplay V1 1 Https://Beoworld.Org/Wp Content/Uploads/2025/01/Beoplay V1 1
Https://Beoworld.Org/Wp Content/Uploads/2025/01/Beoplay H3 1 Https://Beoworld.Org/Wp Content/Uploads/2025/01/Beoplay H3 1
Https://Beoworld.Org/Wp Content/Uploads/2025/01/Beoplay Form 2I 1 Https://Beoworld.Org/Wp Content/Uploads/2025/01/Beoplay Form 2I 1
Https://Beoworld.Org/Wp Content/Uploads/2025/01/Beoplay Beolit17 1 Https://Beoworld.Org/Wp Content/Uploads/2025/01/Beoplay Beolit17 1
Https://Beoworld.Org/Wp Content/Uploads/2025/01/Beocenter 2 1 Https://Beoworld.Org/Wp Content/Uploads/2025/01/Beocenter 2 1
First of all you need to make sure there are no "products" in the zone you want to remove, then go to the zones tab, right click on the the zone you want to to delete and the option to delete should be in that list. Stoobie
Exeter, Devon, UK
First of all you need to make sure there are no “products” in the zone you want to remove, then go to the zones tab, right click on the the zone you want to to delete and the option to delete should be in that list. Stoobie
Thank you very much, Stoobie!!
