BeoCom 6000 problems with the battery load indicator
Hello, I replaced the battery in my BeoCom 6000.
It works fine and also has sufficient battery power.
But when I click on the weel it no longer shows the battery charge, beeps a few times and the display shows 'battery empty'
Do I have to reset something or what could be the cause of this.
Assuming it's a BeoCom 6000 Mk2, on changing the battery you should press: 9#9#9✱655 OK
Guy
I entered the code but there is no difference.
Maybe it is not a Mk2, serial number is 15734840 and it is from 1997.
Is there another method-solution ?
Sorry but that's the only battery reset procedure that I know - I think it may work for both Mk1 and Mk2 models.
You could also try resetting the handset - make a note of any stored numbers first. You may also want to be sure that your PSTN base does not have a pincode set.
If it's a Mk1 (dot button to the left of the circular wheel), press (dot) then 70009
If it's a Mk2 (INT button to the left of the circular wheel), enter the service menu by pressing: 9#9#9✱INT then scroll to 'reset handset' and press centre button.
You will have to re-register with the PSTN base after a handset reset, which may need a pincode as mentioned above. Default is 0000.
