Beocom 6000 shared phonebook transfer/copy
Is there currently a way of copying a shared phonebook to/from a Beocom 6000. Some years ago, I managed to do it wth a B&O serene which connected to the shared phonebook on a 6000 but also had bluetooth. I can't remember quite how I did it but, somewhat academic, as the Serene but the dust many years ago. Surely there is a way?   Many thanks.
I should have been clearer! You have answered a question but not what I had intended! I mentioned the Serene because it allowed me to transfer the phonebook to/from a non B&O Beocom device via a PC with bluetooth. I know about the common/personal phonebook but I want to get data to/from the non B&O "walled garden"! Can you answer the revised question? Lindsay
As an aside, the common phone book should be stored on the PSTN as well as on all the Beocoms registered to it and set to common. You should be able to scroll through them even when outside range of the PSTN. Registering a new handset set to common should have the common phone book together with redial and caller ID lists transferred to it as part of the process.
