Beogram 5005 needle biasing to outside of record
Good news and bad. good news: Adjusting the pickup parallelism really does seem to correct this problem. bad news: screw D is stripped (standard screws should be outlawed) and that’s the screw to make the adjustment properly. For now. I’ve shimmed something under the plastic pin that goes up against set screw D, to rotate the pickup parallelism a small amount. If I can’t eventually get that screw moving, I will tack glue a tiny piece of plastic thereto effect a reversible but longer term repair.
I sincerely hope none of this is offensive to anyone. I’m ultimately trying to keep the deck in service, nobody around here is going to be paying for a replacement cartridge any time soon, and I’m hoping that nothing I do is going to permanently alter the 5005 in a negative way.Please Log In to Reply
