Beolab 5 - Adaptive Bass Calibration can’t complete
Hi, i’have bought a pair of Beolab 5 and for one for one of them I can’t complete the calibration. I starts, but then it stops and the led starts to flash green. Any ideas what do? Cheers,
No ideas?
1. Try a long press of the calibration button to reset. 2. When I had BL5s, they could only accommodate 10 calibrations before they locked up and needed a Service Engineer to clear the memory. I don’t know if this was Mk1, only or mk2?
Flashes green only? Looks like it didn't store the calibration parameters. Could be a fault in a memory chip in the chassi.
Anyone knows if the IC304 is the responsible for storing calibration data?
Thanks for your replies ? How can I identify if the memory chip is broken? Is it possible to replace?
Any ideas? Cheers,
Hi again, the investigation continues. I have tried to long press, nothing. I did try to calibrate once more:
  • The led starts to flash green
  • The mic comes out
  • Then nothing, no sound
  • The mic goes back
  • The led starts to flash red
Any genius that can help me?
Try to play the BL5. Does the lower woofer at the bottom vibrate while playing music?
Yes, all elements seem to work
