Hi, all.
I'm new here, so please let me know if I'm posting in the wrong place or made some other fundamental error.
I have 2 problems with my Beomaster 5000 (type 2322):
- The output transistors/heatsink get very hot after just a couple of minutes, from switch on, with no load.
- With speakers connected, and an audio source connected, the left channel seems very quiet (the right seems "OK")
With no-load, and measuring with a cheap IR thermometer, the transistors quickly exceed 40 degrees C. This surprises me. I daren't risk leaving the unit powered up for any longer after that, in case I do more damage.
I tried following the setup/trim recommendations from a (blurry) photocopied service manual I found on line, as follows:
Set the receiver in mode P1-P9.
Adjust the no-load current while the receiver is cold and with the volume control turned fully down.
Loudspeakers must not be connected.
Connect a DC millivoltmeter between 2TP2000B1 and 2TP201C2 (2TO100A1 and 2TO101B1).
Adjust with 2R226A2 (2R126C2) until a reading of 11 mV is obtained.
The trimpots appear to be 100 ohms (with one leg tied to the wiper?) and resistance varies, as I'd expect, when the wiper is turned. However, I'm reading 42V (that's VOLTS - not milli-volts) and, intermittently NO VOLTS, between the measurement points, specified above. I cannot get near the specified 11mV, no matter where I set the trimpots. The fact I get OK sound out, with speakers connected, from both the tuner and tape deck (and, until it died couple days ago, the CD player) - albeit with a quiet left-channel - makes me think the unit is
basically OK. Question: in the above text, does
2TO100A1 and 2TO101B1 actually mean
2TO100B1 and 2TO101C1, or
2TO100C1 and 2TO101B1 ?
I'm pretty sure this used to work fine. It's been stored for around a decade, so my thought was "maybe dried up electrolytics", BUT I simply don't know where to start diagnosing the problem(s)! I have a
basic understanding of electronics and am quite happy swapping out components, and making adjustments, but I don't want to start randomly swapping stuff out (I'll end up causing more damage, I'm sure).
BTW: I
have been through quite a few older posts which mention the overheating issue, but I'm not sure if/how these relate to my issue(s).
If anyone has experience and/or wisdom they'd care to kindly share with me, as to how I might approach this, I'd be very grateful.
Many thanks, in advance.
Kind regards
Andy
