Beosound 9000 - glass lid won't stay up
as the title says, more often than not it will require a couple of tries before it lifts, and then suddenly it will drop the glass lid.
Same problem as described here in the archived section, and with link to another thread where it is suggested that there is a repair kit to be had? And also that it might help to change the belt.
So far all is good. My question is if anyone knows where I can source a belt, the aforementioned repair kit for the mechanism, or a new mechanism itself.
https://archivedforum2.beoworld.org/forums/p/20576/168761.aspx
https://archivedforum2.beoworld.org/forums/t/10243.aspx
Any pointers greatly appreciated!
I'm not interesting, I'm into resting
Hi, I had the same issue. I have ordered the belt on www.webspareparts.com :
https://webspareparts.com/products/door-belt-for-compact-system-bang-olufsen-beosound-9000
J Ferré
Thanks a bunch, just ordered a couple. As long as the unit is vertical the mechanism works as it should, but it in horizontal position the lid falls down, hopefully this'll sort it.
