Hi beoworld,
So Im not getting television programming just black and white fuzz on each channel going up to channel 69.
I am able to access the service menu and TV TUNER submenu with the old “menu, menu 0, 0, go combo” — and see many on and off options.
TUNER SYSTEM
B/G is OFF
L OFF
M ON
D/K OFF
I OFF
My dtv is programmed to antenna via AV 3 and the tv button is also programmed to antenna (via air signal) the beosystem 3 is connected to an antenna hd loop receiver with the two rabbit ears by phillips. Though i understand there is a built in tuner also. I am less than 5 mi away from a tv signal tower per the public map that indicates that my neighborhood is covered.
What steps or tips do you suggest for troubleshooting this and getting the local over-the-air channels going for television programming?
ive turned it the antenna setting on and off a few times to no avail and switched out the antenna for another brand from philips two prong ears to a flat square object placed about 8 to 9 feet up.
im located in the US for any regional requirements in setting the menu options. You will see the image shows the menu options im seeing. Most are grayed out and im not sure how to toggle those if necessary?
thanks in advance for pointing me to various resources or walk throughs!
Simply looking forward to watching some sports on local tv broadcasts :-)
Beosystem 3 tv programming
