B&O Avant DVD CRT TV HDMI to RGB SCART connection?
I've just got hold of a near mint B&O 32" Avant DVD CRT TV. Everything working and came with the BEO4 remote that also works.
I'd like to create a HDMI to RGB scart connection to the TV but know from searching the web in general that it's not straightforward and that HDMI to S-video is simpler via the TV's camcorder input.
However, does anyone know if there is a simple way to do it?
I've been reading that HDMI to VGA to RGB scart is one solution or HDMI to component to RGB scart. However, most information I can find seems to indicate that people who have tried this find it doesn't work and end up using the HDMI to S-video method. These methods are also rather convoluted.
I actually want to connect a Firestick to the TV with the best possible quality via RGB scart.
I'd be really grateful if anyone can help, even if it's confirmation that it's not possible and that connection via the camcorder inputs is my only option.
IF HDMI to RGB SCART isn't an option then...
There are quite a few well reviewed HDMI to S-video converters on Amazon that look like they'll do the job. I'm looking at this one:
https://amzn.eu/d/0gNCr8yf
I'm assuming that connecting one of these to the TV's camcorder S-video and L/R audio will work? I've found something that says when the Firestick is connected up to press the rewind and up buttons on the Firestick remote and it'll cycle through resolutions until it finds the right one.
Many thanks...
