Afternoon,
I'd like to check my options for Master Link between my MX8000 and Ouverture system.
I have a pair of 6000 speakers connected to the Ourverture, but would like the option to play TV/DVD audio through these speakers.
I can do the opposite: I can use (Beo4) AV -> Go -> Radio/CD/etc to play Ouverture sources through the MX, but not the reverse.
Most guides seem to suggest that I should connect the speakers to the TV. Is this my only option?
For this is I should use A.Opt: 0, V.Opt: 2
Following the table below I have tried A.Opt: 1, V.Opt: 1, but not sure what else to do after that.
The MX8000 manual refers to a CD-ROM for additional settings, but I have so far not found this material online.
I do have a Beolab 2000 in a linked room which is working just fine: Hit DVD from the Beo4 and I have TV/DVD audio.
What else can I try for my main room setup?
Thanks in advance, Neil
