Lab 28’s Curtain Control
My lab 28’s are connected using wireless link to the Theatre. When I select TV mode, I have configured for just the Theatre speaker to be active. However, the curtains also open on the 28’s. No sound comes from the 28’s on TV mode and only the Theatre works, which is correct and exactly what I have programmed it to do when the source is TV. What I’m asking: is there a way to have the curtains stay closed or close when the selected source does not require the 28’s and only activate if the source requires the 28’s and then close if the source does not require it. I think this adds to the ‘wow’ factor. Interested to know if this is an option.
Hello George, This issue is standard behaviour on all Wireless Power Link speakers due to TVs/Theatre sending data in all speaker setups at start-up, which causes all speakers to switch on briefly. Work Around The only known workaround is to use wired Power Link Kind regards, Pete
Peter Fraser Service Technician Multicare Electronics
