Hey everyone,
I’m planning to renovate a pair of Beolab 8000 MK1 speakers. From what I understand, I’ll likely need to replace the internal foam damping material since the original foam tends to deteriorate over time.
Does anyone know the technical specifications of the original foam that Bang & Olufsen used?
- Foam type/material
- Density
- Thickness
- Templates or blueprints for the different foam pieces?
- Measurements or diagrams for the internal foam layout?
