Light control with Beoremote One + Mozart + Home Assistant
I've made a video for those of you, who are interested in a relatively easy way to activate light control from Beoremote One through a Mozart Platform-based product and Home Assistant. This video takes you through the first-time setup of Home Assistant and how to set up the automation :)
https://youtu.be/ju_gQDIme0w?si=Zj_FD9VVvlrIU1WM
Very interesting, thank you.
Light control through Beo4 and LC2s were so comfortable, I miss this feature very much.
Happy to see there is a solution.
Regards,
Yann.
Infected at the age of 13 by a BG 4000 in Dad's Hifi shop.
Tak 👍
The only drawback here is, that I need light to see which buttons on the remote I should push…..to get light.
Unfortunately not.
That is possible in IR mode on Beoremote One, but unfortunately not when using Bluetooth.
@cklit
Hello,
It seems that Home Assistant can be installed on a Synology NAS.
Chance for me, I have a Synology and a Theatre, so I am thinking of using your script for control with BR1.
Do you know if it's possible?
Kind regards,
Yann.
Shouldn't be a problem :)
I'll keep you posted :)
@cklit:
Done and running, I was really missing this feature.
Thanks again for this brilliant work!
Yann.
I'm glad you like it :)
