Hello Beoworlders,
Newbie in Home Assistant, I discovered the Beoplay integration in the HACS repository and installed it together with the Bang & Olufsen one.
I activated 3 devices: Core, NL/ML converter and Beosound 1, plus the media player entity for each of them.
When I open a device, I have this screen:
Login to view image
I use to listen to playlists and to reach them, I use the "parcourir les médias" command and drill down in the following screens: DNLA servers, Twonky media (installed on the same NAS as Home Assistant), Music, Playlists:
Login to view image
As you can see on the bottom-left , a "play" button exists, but is not responsive.
A double click opens a new screen with a "play" button, but the result is the same:
Login to view image
And if I select a single song it's played but the music stops at it's end and the following song is not played.
The result is nearly the same if I choose to listen to an album with this differences:
- No "play" button on the album's artwork.
- A single or double click shows the list of the son
What did I miss?
Other question, is there a way to add "shuffle play" in the commands of the main screen?
Thanks for your help,
Yann.
