Hi all,
This Beosound is another one from an inheritance. On powering on the only thing that happens is some clicking of the relays. Then all CD lamps light up, afterwards another click and it reboots it's sequence. It does not respond to anything (remote is dead also). Now I want to check several pcb's but there is a problem.
You see to get at the pcb's you need to move the cd arm to a specific position. Otherwise you can't remove the plastic cover. But my machine won't let me input any codes (SHIFT + numbers) to release the arm. It won't let me do anything at all for that matter.
As far as I can see the service manual does not say how to move the arm manually. There has to be some sort of mechanism seeing that servicing the machine would be rather impossible otherwise.
Does anyone know the procedure to manually move the arm to the central position?
Many thanks,
Bert
