Can anyone confirm whether or not the software version on the Beo5/6 updates when using the Configuration Tool offline. i.e. Is the software included in the CT installation files or does it need to be connected to the B&O server to update?
Also, am I correct in saying the Beo5 can only be used with a 32bit machine regardless of software version on it or version of CT used?
Thank you Stoobie
Login to view image
Exeter,
Devon,
UK
