Beocenter 1800 arm lift mechanism problem
Hi, I was working on a beocenter 1800 and an arm about 30cm long fell out. I don't know where it should go. I attached a picture showing it. I cnat find it in the service manual. Best regards, Karri
That appears to be Figure 142 and part 257022 Arm, Speed in the manual.
Hi, Mark! Unfortunately the part isn't 257022. That part is in it's correct place in the mechanism. Do you have any other suggestions? Do you know if the turntable mechanism on the Beocenter 1800 is reused in some of the Beogram products? Maybe a different manual for a similar mechanism would show the mystery arm. Best regards, Karri
Finally! It was part 2570056. It connects the 'lift' button and the mechanism actuator relay/thing. Karri
