BeoCenter 2 - Display Backlight repair
Hi all,
So happy the forum is back again. I found an old BeoCenter 2 in our basement and tried it yesterday. After a few hours of search for the Pin Code all seems to work fine.
The only problem is that the display backlight is very dark because of its age. Is there an easy way to repair the backlight? I assume it is kind of a foil? I hope I don‘t have to change the whole display ;-)
Br
Tim
P.s. I see a DAB connector on the master unit. Does this mean it has already DAB? Can‘t really remember.
Hi all,
I just opened my BeoCenter 2 and fully cleaned it. Next step is remove the sticky part of the soft paint.
It looks like the Display is a VFD Display. Looks like a new repair part is pretty expensive. I think I will stay with the "dark" one ;-)
I have a BC2, too, but it's boxed away at the moment.
The specs mention that "Contrast on the display adjusts automatically to light conditions,ensuring that the display text can always be read easily" and
"Bang & Olufsen - A Life Less Ordinary" // "It's not magic, it's the Bang & Olufsen link system" // "It takes more upon itself, asks less of you. And a natural consequence of this is the simple and striking design. The true harmony of form and function spells beauty in any language"
