Beocenter 2 CD tray belt
I have recently aquired a Beocenter 2 that need some attention.
For one thing belts. Beoparts shop has the belt for the Door mechanism, so no problems there.
But the Belt for the CD tray mechanism also seems to be a little loose (The tray can not fix the CD in place) , but Beoparts shop does not have a belt that will fit.
Does anyone have an alternative for this?
The Belt is round, 1.5mm thick, and aproximately 30mm outside diameter. The correct outside diameter may of course be a smaller number since the belt is loose.
Thanks in advance
Having dismantled the whole CD tray to get a more precise measurement of the Belt I have now measured it to 29mm outside diameter.
I have found an Ebay seller who has belts in the right thickness with both 25mm and 26mm inside diameter.
Have ordered some and will see if the will work.
Have now received and installed the new belt for the CD tray. I used the 25x1.5mm one as the 26x1.5 was the same size as the existing one in the BC2.
The CD tray now works just as it should, and the BC2 can also play both CD's and DVD's
