Beocenter 2200
What parts are not available? Check if the motor bushing touches the metal bracket. If it does - replace the motor mounts. https://www.beoparts-shop.com/product/motor-suspension-rubber-bushing-grommet-f-several-beogram-beocenter-models-2/ If the motor itself is noisy, it must be taken apart and repaired (most can be) - or replaced, and a good condition used original motor would be the way forward in that case. Martin
Thank you. I will investigate.
I have obtained a 1980s  Beocenter 2200 and find the 6 very fine wires to the stylus have become detached at the printed circuit board end . Would it be possible to re solder these ( circuit diagram needed) or can the assembly be replaced please ?
