Hello, my belt snapped, cant figure out how to install the belt. Where does the belt go?
Usually on other turntables you just pull the lid off , but this one seems more complicated...
Do I need to take the whole thing apart? Screwed off all the "C" screws, but the turntable still won't come off, do I need to unscrew all the "A" screws as well?
Also is the size of the belt important, someone told me I could just glue the belt together at the breaking point...
beocenter 2200 Driver belt installation
The platter lifts off to replace the drive belt. You need the right one which is available from beoparts.com.
