Hi
I had a Beocenter 3500 which I tested worked OK (it was my late fathers). All was fine, I gave it to my son but as soon as we tried it, the belt came off. He ordered a new one but the same thing happens. Any advice very welcome, thank you!
Beocenter 3500 belt
Did you order the belt from Danish Sound Parts (formerly Beoparts)?
If not, then I wouldn't necessarily trust it to be correct!
Losen the three transport screws. They are found under the platter.
With the transport screws tightened for transport the belt will almost always come off when the motor is started.
The same goes for Beogram 1203, Beogram 2000, Beogram 3000.
Thank you! We will give it a try
