Hi
My Beocenter 5000 dust cover will not stay open. Is there a straightforward fix for this? I'm happy to remove the cover in order to fix, however have read they are tricky to reinstall.
Thanks in advance
Mick
The spring has lost its tension.
Take it out and twist it from both ends towards the center to add more tension.
Thanks Martin, I'll give it a go. Cheers.
Oh dear. Sorry Martin I gave it a go but now can’t get it reattached at all. Any suggestions would be GREATLY appreciated from anyone.
