Beocenter 6 23 software upgrade?
Because of space constraints I have now bought a BC6-23 to replace a BC6-26.
But I might not have done enough research beforehand as the BC6-23 does not have the ability to assign other sources than "PC" to the DVI connector and also no possibilities for PUC for the DVI connection. This is functionality I have on my BC6-26 and would like to have it for the BC6-23 also to be able to integrate an Apple TV.
The BC6-23 is a type 9212, with software 8.6
My question is: Is it possible to update the software for this type number to gain the functionality described above?
Looking at some older threads I can see that type numbers 9219-9226 should be able to get software 10.10A where a HD upgrade kit is mentioned, but not sure if that is needed to get the functionality I am after.
Space constraints.
From 26" to 23"
? - that must be a tiny space. Sorry for the off-topic answer. Couldn't help it.
Since these TVs are worth 0 now a days... It might be easier and cheeper just to get another Beovision 6-22 or Beocenter 6-23 ... ?
Beo-museum ?
According to service manual of BC6-23 MK1 type 9212-9218:
Softwareprogrammering
- Programmet M2
- STB-C-tabeller
NB: Anden software end ovennævnte kan opdateres ved at udskifte EEPROM’erne
i hovedmikrocomputerens modul 6.
Something like that :-) my little limited space for toying with those beatifull things.
Lovely Beocave!
Beofan for many years with a penchant for 1990s audio systems.
