Recently my beocenter started to have an issue with the record player , it spinns very fast without corecting the speed if i press 33 or 45 , i put it on service mode and measured the pins of the motor wires while i had pressed the turn button , it runs on 13,7 volts!! any suggestions? is the turntable board faulty?
beocenter 7007 RECORD PLAYER SPINNING VERY VERY FAST
Goodmorning , thank you Martin for your responce , i did check the trimmers moved them anti-clock wise but nothink reduced the speed , the motor is 3 v but i measured 13.5 on the pins in motors socket while i had pressed the turn buttonCheck for cracked solder joints - especially where connectors are soldered into PCBs. Check also the supply voltage to the motor control circuit. Martin
