Beocenter 8000 questions
Hi everyone After a 15 year break, I am planning to get back into B&O. I once owned a Beocenter 8000, which I really liked but then my circumstances changed and I did not have room for it anymore so I sadly sold it. But now I have room again and I am still in love with the design. So a week from now I am going to visit a seller who has a Beocenter 8000 and a pair of Beovox 3000 for sale. So the question is, what should I be looking out for? Seller says everything is in working order but I am obviously going to get a demo. Tapedeck and CD are obvious things to test but is there anything in particular I should be looking (or listening) for? I also have zero experience with Beovox 3000. Back when I owned the Beocenter I believe I paired it with two Beovox C40 and later a pair of M150. How would the Beovox 3000 compare? Also, while we’re at it, if I buy the Beocenter, I will probably start looking for a Beogram to match with it. I would like it to fit designwise so I think Beogram 8500 or 9500 are my best bets?   thanks for any help.
Just seen this and you may have bought it by now, but in case this is still of any use to you, I have a Beocenter 8000 (in fact, it's for sale on eBay at the moment as I replaced it with a Beocenter 8500).  Here's what I found with mine: Good luck with it and let me know if you need any help with it.  I really did love the look of my Beocenter 8000 more than the 8500 that I replaced it with (the black gunmetal finish is really nice), but I needed something that would work with active Beolab speakers, and I also wanted to add extra speakers using an MCL multiroom box.  The 800o is not suitable for those, whereas the 8500 is (as are the 9000 and 9500, and I think the 9300 is too, but I never owned that one).
Should also have added - ehile I did not have this problem with my 8000 or 8500, I did have this problem with my (older) 9000 and the 8000 could have the same issue - check the Speaker 1 outputs are working, in case the mute relay has stopped functioning.  Again an easy fix, but requires soldering.  See https://forum.beoworld.org/forums/topic/beocenter-9000-restoration-2-issues/ I have ordered a new mute relay for my 9000 from Beoparts (now: Danish Sound Parts); it was cheap and was delivered earlier this week, I just haven't got round to fixing it yet.
Old enough to have gazed at classic B&O HiFi in Plumbs shop windows in the 80s...
I never had this problem with my Beocenters but I did with one of my Beograms; new rubber feet and a more solid shelf solved it for me. If I hold my ear close to it there's still a hum, but you can't hear it normally.
I don’t think it’s the rubber feet. I’ve tried having the BC9500 on other surfaces (one even of rubber) and the same thing happens. It definitely sounds like the sound is coming from the internal power supply.
I happened to have a transformer unit in a drawer from a Beocenter 8500 which I broke down for parts - I've just taken a look at the 8 rubber bushings and they are rock solid; in fact one of them broke to pieces while I was inspecting it.  My understanding is that the transformer unit (part ref PCB64) is the same in the 8500 and 9500 - not sure if anyone can confirm that? Since the bushings are so cheap and the transformer unit is relatively easy to remove, I think it would be worth a try.  There's a reasonably good chance that they are the cause.
