Beocenter 9000 RCA Connections to Beolab 6000's (left channel is low)
I am attempting to connect my Beocenter 9000 to Beolab 6000's with RCA cables. I noticed the right speaker/channel sounds like it has normal volume, but the left speaker/channel sounds much more faint. Is there a setting or switch to correct this so they both sound the same? TIA!
You could check to see if the balance on the BeoCenter 9000 is correct. If set too far to one side you would have a similar issue.
Bang & Olufsen classic service centre. Repairs and refurbishment to both old and new.
