Beocenter 9000 restoration - 2 issues
I just picked up a Beocenter 9000 cheap on eBay, as a restoration project.  It was in surprisingly good order, I was particularly surprised to find that CD and cassette both work (although I probably will replace the tape belts anyway).  Apart from a little scratch on one of the doors, it's in great cosmetic condition too. There are only a couple of issues but both things I have never fixed before so I am looking for some advice. Door Cords: the door for the tape deck is not functioning, all parts are there, they have just come loose. I have never had to re-cord the doors on one of these before and for the life of me I can't figure it out.  The door cord instructions from B&O which are
Old enough to have gazed at classic B&O HiFi in Plumbs shop windows in the 80s...
Have a good read of this thread about the door strings:
Thanks - I did figure out the door strings after a lot of messing around (don't ask me how!).  I've managed to get one of the two back in place, the other one is almost there, I just need to get the knotted end into the little slot that holds it there - I've had enough with it for tonight, I'll try again tomorrow. I've just read about that speaker power relay on Beoparts and you're almost certainly right.  I need to order tape belts from them anyway so I might as well order that too.  I'm assuming it will need soldering in place?  With any luck then I'll be able to get it into full working order!
Yes it needs soldering - here's the relay in a BC9500:
Ah yes, I've found it in my 9000 now (it's actually pretty big and obvious, now that I see it). I'm not the best at soldering which is why I asked, but my partner has a steady hand - he can do it!
Update - I manage to fix the door cord; tape deck door now working!  It also needed a new door belt but luckily I already had a spare.  That took a lot of patience and a lot of repetition (get one bit in place, another bit comes loose...), but I got there in the end. I'm also even more sure than I was yesterday that you were right about the mute relay
Sorry I've realised I didn't phrase this as a question in my last post but there was a question, if anyone knows - would the amplifier unit I already have from a BC8500 fit into the BC9000 as a straight swap?  It looks like it would but I don't want to risk it and then see smoke coming out of it! Although the amp is out of a broken BC8500, the amp (and speaker outputs) were definitely fully working, including the mute relay.
That's what I thought - I have a few days off work so have the time to try it.  The connections actually all look in pretty good order. I do still intend to order the mute relay and see if I can fix the original amp in the BC9000, but just in case that doesn't work, I have a backup.
While I was poking around inside the BC9000 I also decided to try to get the cassette mechanism out and have a look at the belt.  It's the Type 1 cassette deck; I've only replaced belts on the Type 2 before now. The cassette deck does work, but I also have a Beocenter 8500 which is the one I use, and the tape deck in the BC8500 can be a bit temperamental sometimes, so I want to put a new belt in it. My BC8500 also has the Type 1 tape deck, same as the BC9000. So, I thought I would take a look around the tape deck in the BC9000 (a restoration project) so I would know what to do when it came to replacing the belt in my BC8500, but I cannot figure out how the get the tape deck mechanism out!  There are three screws (two on the lower edge, and one above, next to the motor), but something still seems to be holding it in place at the bottom edge, that I can't see it. Has anyone here ever removed one?  What's the trick to it!? I have checked the service manual but it does not go into the level of detail needed, or not that I can see.
