Beocenter 9300 after replacing CD doors it behaves crazy
I had to replace doors at my Beocenter 9300. It was aaaa lot of work, but finally I made it !
Unfortunately not all went right. Doors are working opposite. What it means? When I start CD it opens a door and... try to start disc on open drive !!!
When I turn CD off it opens doors instead close them...
What I did wrong ? Doors for a Deck that I didn't touch (only changed the belt) works properly.
Please help as I cannot find any good service documentation to my model (9300 from 1996).
Regards,
Radzio222
I can give you just the cord diagram - as viewed from under (inside) the BeoCenter:
Login to view image
The full manual is on the site available to gold and silver members - see here:
It sounds like you have the cords wrapped around the drive shaft in the wrong direction. They initially go over the top, then under. There are some pictures in this thread:
No I couldn't find any. If you could share with me, It would be great.
That was my suspicion that I made it opposite. So another a lot of work with my Beo :(
If the motor leads were desoldered, they could also be reversed.
Guy, thanks for hour help. This picture helped me a lot! Door are now fixed. Thank you very much!
