Hello, does anyone know the weight of the platter? The platter which had come on my 3300 has a pretty heavy circular black weight that it glued underneath while the replacement plattter that I bought from ebay does not have it and is very light. I wonder which one is the original if anyone could kindly confirm? Br
Beocenter3300 platter weight
Actually, both are correct.
Early Beocenter 3300s have the platter from Beogram 2200/2400 etc.
Later the one from Beogram 2202/2402 was fitted, - and it has the extra black weight strip
underneath.
The later and heavier one has marginally better specs.
Thanks a lot!
