BEOCENTRE 9300 Tape Malfunction
Hi, I inherited a Beocentre 9300. Unfortunately the tape section does not function. When attempting to play a tape I can hear clicks but no motor noise or movement. Advice to possible cause would be appreciated such as belts or more serious malfunction.
Many thanks in advance
Im guessing now, but belts would be my first bet.
Thanks for your reply. I found a video showing how to access the working parts although it was for a cd fault. Not sure of my skill level with this but will proceed with caution and if it's not the belts will have to source someone who can repair.
Happy to report that I had success with fitting the three belts for the tape section and the tape is now fully functioning. Not bad for someone approaching eighty with age related hand trembling.
