Beogram 1202 to Beocenter 2300
I have a Beocenter 2300 connected via Powerlink cables to Beolab 6000 speakers.
CD sounds fabulous - deep, rich room-filling sound at Volume 40.
I have connected my Beogram 1202 using the integrated 5-PIN DIN output plug to the AUX input of the Beocenter but the volume is really low. At Max volume 90 it is audible but not loud. I have been using the Beogram with a Beomaster 3000 with no issues.
There are no other inputs so any advice on how to resolve the issue. Do I need a phono stage between the Beogram and the Beocenter? If so, any recommendations and what cable should be used to make the connections given that I will probably have to go from DIN to RCA and back to DIN.
Thanks in advance for your help.
https://soundsheavenly.com/products/pre-amp-bundle-for-b-o-beogram-and-all-turntables Or this one from OneRemote would 'future proof' your system because if you buy a non-RIAA remote-controllable B&O turntable in the future it would allow remote control: https://shop.oneremote.dk/shop/69068-riaa-forstaerker/121270-riaa-iii-forforstaerker/ Hi Guy and thanks for the welcome. I guessed that it would be a lack of a pre-amp that was the problem but I read that the 2300 had a built in phono amp - clearly & not surprisingly the AUX input is a line level input not a phono input. Thanks so much for the advice - I'll get one of the above pre-amps and enjoy listening to my vinyl collection through the 2300. Cheers Rob
