Beogram rx2 to beocenter 8500
Hi, need help to connect a beogram rx2 to a beocenter 8500, what connector should I use? Thanks
My Beogram RX2 is fitted with standard RCA plugs rather than the usual B&O DIN plugs, and my understanding is that this is normal for the RX2 and TX2, as they were intended for the wider market (in fact, my own RX2 is connected to a modern, non-B&O amplifier via standard RCA connection). You just need an RCA (female) to DIN adapter such as
Old enough to have gazed at classic B&O HiFi in Plumbs shop windows in the 80s...
