Hi, I'm carefully resurrecting a Beocenter 4000. I have isolated a faulty component and am having much difficulty identifying it. I believe it is some sort of adjustable tank circuit resonator.
It is on the outlet of the audio of the FM demultiplexer/decoder chip.
The text on the side is '5214 48 JL' it is identified in the tech manual as 'LP200 8030041 19/38 khz'
I've included photos of the component and the circuit diagram.
If you can help, thank you so much.
identify component for Beocenter 4000
It's an MPX filter. It grounds remains of the stereo pilot.
You can fit any good similar filter - or ask at Beoparts for a good used original part.
Thank you Martin, that's the info I needed!
I've found an equivalent component to buy.
Now to find out why the signal strength meter is is not working...
