Anyone know or have ideas where I can get a new plug?
One end of the cable, the plug is beginning to disintegrate!
Master cable plug
They can be found on ebay, but a special crimping tool is needed.
Another option could be to get a small piece of masterlink wire with a plug and splice the new cable with the existing one for example with a ML junction box or soldering and heat shrinking the connections
I think a little confusion rules, I am looking for the plugs or the link cable between the head unit and the master box
Oh its for the Beocenter 2, in that case I am not sure you will be able to find the plugs separatly. So you might go for a new cable
Ok, thanks
You need to buy a complete cable the plugs for beocenter 2 cannot be bought
