Trigger BeoCenter with 12v
Hello everyone! I was wondering whether I could turn on my BeoCenter 9500 with a 12V trigger. Ich Currently have a Sony TV connected to a Yamaha WXC-50 Wifi Receiver via Toslink. (The Yamaha turns on automatically when the TV starts with a Google automation) That Yamaha is then connected to my BeoCenter 9500 with a DIN to Cinch Adapter. The Yamaha has a 12V Trigger input and Output. I was wondering, how and if I could turn on the BeoCenter when the Yamaha turns on. Right now I turn it on manually with a Beo4 Remote. (Don't really mind using it as its a classic, but my Girlfriend finds it rather annoying) Has anyone ver done this? Is it even possible? Thank you in advance for any help and answers :) Regards   Flo from Switzerland
Beolab 8000 + BeoCenter 9500 + Beogram 9000 On the lookout for a Beolab 11 or 2 to finish off the system. Also interestet in broken ones as I like fixing stuff myself.
Solution 1: If you use Google automation, find an IR emitter B&O complient and code some commands. Solution 2: Change the girlfriend?
