So im working on a beocom 2, seems like an early mk2, production date 040414 and sw Version 0049-1.5-1
I want to get it into registration mode so it pairs with a base Station. Using 9#9#9* INT brings me into the service menu, but all i can see is the sw version and delete phonebook etc. Also tried disconnecting the battery, but that also did not help. Is there any option to reset it? Best regardsBeocom 2 how to reset
In the regular menus, not service menu: Settings / Base / Remove gets it off an existing base. Settings / Handset / Register gets you on a new one.
Also: /api/files/c78f19d42fe54c29bb113605b20c3550
Unfortunately there is no such option. Setup menu Looks like this
- Ringer Level
- Time & Date
- Display News
- Auto offhook
- Language
- Flash Time?
- Resettings
- Delete Caller ID
- Delete Phonebook
The format of your date and SW version makes me think that this is an early, original Mk1 Beocom 2 that will only register to its own original base (that was built into the charger base).
Have a read of this thread which sounds like a similar problem:
I also start thinking that its somehow hard coded to a base. But it came with a charger only, no base with a phone cable. Also, it has the newer battery clamp, completely different to my MK1 i have here. Maybe i can find a dealer who can help.
My own Mk2 is a mixture of parts from a Mk1 and Mk2, both bought ‘not working for spares’. I wouldn’t read too much into the battery clamp and base that it came with. I think the SW version is probably the best indicator of the actual type.
You think a mk2 board would fit into it if my dealer cannot help?
