BeoCom Technical Advice Required
The old phone lines have been phased out in my area and now they connect via the internet router (VoIP), I’ve plugged the BeoLine Mk2 into the hub, making external calls is fine but nobody can phone me, rings once their end not mine then drops the call, I’ve tried a ADSL Filter with no joy, hopefully there’s a solution because I love my BeoCom 6000’s and BeoCom 5’s it’ll be sad to see them moth balled
Thank You
Sitting: BeoVision 11-46 on Motorised Floor Stand - BeoLab 11 Wall Mounted - BeoRemote One - BeoCom 5 with Speaker Base Dining: BeoGram 3000 Type 5228 - BeoSound Core - BeoLab 28 - BeoRemote Halo Kitchen: BeoSound 1 - BeoRemote Halo - BeoCom 6000 Bedroom: BeoSound 35 - BeoRemote One - BeoTime Guest Bed: BeoLit 20 Study: BeoSound Core - BeoLab 8000 - BeoCom 5 on Speaker Base Gym: BeoPlay A9 On The Go: BeoPlay H7 - BeoPlay H5 - BeoPlay E8 3.0 - BeoPlay H95 - BeoPlay EX
Suggestion: Name your carrier & location, and the CPE model number. Thus someone knows if their experience might be helpful to you.
An experiment you could try is substituting an old bell ringer phone, or even a moderately-old AT&T slimline. Does that work? Then parallel it with your Beoline. Does that work? "Their end not mine drops the call" implies that something on your end is picking up and immediately hanging up, though it's not clear where in the chain that something is. A DSL filter added should both be unnecessary anymore, and should make no difference, which it doesn't, so that's good at least.
I once had that problem. I solved it by restarting the modem while BeoLine connected to it.
Thank you trackbeo for your reply, I’m in the United Kingdom and with a provider called Virgin Media using their Hub 4, tried the suggestions with no prevail, seen a lot of people having the same issue in the UK on forums when switching from the old phone lines to VoIP, managed to resolve it tonight if anyone has the same issue in the future…
- Unregister all phones
- Unplug BeoLine PTSN
- Plug back in
- Register Phones
Fixed the issue
Hi, I have the same Beocom 6000 PSTN setup as isthat the bedtime. Plus a BeoTalk 1200 connected to a Virgin Media master phone line socket. Well-matched was last week, now I am connect to the hub via voip. I gave exactly the same issues.
Would it be possible to provide step by step instruction, as I have not changed my phone stuff for 10+ years.
Fingers crossed I can keep using this great kit.
Regards Paul
Hi Paul I’ll do my best
step 1. Go into menu
step 2. Scroll to Base
step 3. Scroll to Remove Handset and click ok
step 4. Unplug PTSN Line for at least 2 seconds
step 5. Plug the PTSN Line back in… the light should flash green indicating it’s ready for registration
step 6. The BeoCom handset should say register to base… click okay
step 7. The base should then come up on the display… click ok to register
hopefully that should be everything
hope that fixes the issue
To Isthatthebeotime: I have the same problem having been switched by Virgin to their fibre service using their Hub 3. I have an old Beocom 600o PTSN (c. 1997) but trying this didn't work for 3 Beocom 6000 MK1's and one Beocom 6000 Mk2. I've now tried to use a Beoline 2 with the Beocom 6000 Mk2 without success. Were you plugging into the Hub 3 directly or via the Virgin provided adaptor? I would be interested if this worked for Paul as well or others? Many thanks
Huw
Although I don't have experience of the Virgin Hub, I think that the problem here may be an incompatibility with the wiring of the RJ11 lead.
Both my Beoline (Type 1130GB) PSTN and my BC6000 PSTN use RJ11 pins 3 and 4 for the phone connection (the latter from the LINE socket of the little black 3-way adaptor*). These connections are normally routed to pins 2 and 5 of the BT plug/socket, which works fine.
I think that most UK telephones use RJ11 pins 2 and 5, and perhaps the Virgin Hub 3 telephone socket expects this. Thus you may not be able to connect your B&O RJ11 direct into the Hub's telephone socket.
Try using you original RJ11 lead into your original RJ11 to BT adaptor and then use the Virgin-supplied BT to RJ11 adaptor to connect to the Hub.
* My 3-way adaptor is the version without the white spot - on the right in the picture below:
Login to view image
You can see that the version without the white spot has the LINE connections close together - RJ11 pins 3 and 4.
In the version on the left with the white spot, the LINE connections are further apart - RJ11 pins 2 and 5. If you have this version then let me know and there is something else we can try!
(As you view the socket, RJ11 pins are numbered right to left 1 through 6, but pins 1 and 6 are not used in this application).
For info, on the BT plug the pins are also number 1 through 6, with pin 1 being nearest to the locking lever.
That’s something which originally did think may have been the issue but managed to solve with trial and error despite this
