Beoconnect Core autoplay
I recently procured a Beovision Theatre 77" together with a Beoconnect Core to connect my record player, using the line-in of the Core. When I start playing a record, I need to switch the Core from stop to play on the B&O app before I can join the Core with the Theatre. Can this be done automatically or using the Beo One remote?
v/r Dolf
Can you connect the turntable directly to the line-in (USB-C) on the Theatre? Then you wont have to join the Core and Theatre, it will just autoplay on the the Theatre.
I forgot to mention that I use this setup because the record player is on the other side of the room and can't use a wired connection.
The core should autoplay the line-in when a signal is received. The tricky part is easily joining the Theatre and Core together. Probably the best way to do it would be setting the group as one of your four preset buttons on BR One.
- Use the app to set Core to line-in, and join the Core and Theatre.
- Make sure your listening position and other settings are how you like them to the turntable.
- Then, press and hold one of the four preset buttons on the remote to save that configuration to that button.
