Beocord 5000 type 4715 too slow
Dear all, After replacing all belts on my Beogram 5000/4715, the tape-speed during ‘play’ was noticeably too slow. I read somewhere that this can be adjusted by a certain potentiometer. Where can I find that? I have the (French 80-page) Service Manual, so you can reply using the images in that SM. Or should I first lubricate all bearings with a tiny drop of sewingmachine-oil? Thanking you in advance for your reply, Dirk
EDIT: Dear all, After replacing all belts on my Beocord 5000/4715, the tape-speed during ‘play’ was noticeably too slow. I read somewhere that this can be adjusted by a certain potentiometer. Where can I find that? I have the (French 80-page) Service Manual, so you can reply using the images in that SM. Or should I first lubricate all bearings with a tiny drop of sewingmachine-oil? Thanking you in advance for your reply, Dirk
I would never turn anything around in B&O equipment... only when i exactly know what i'm doing. Clean the drive, the axles, motor with alcohol... it's 40 years old hard grease. First clean it, then oil it. Remove the old stuff 100%... Old grease and fresh oil: after 3 month you have a superglue. Nothing will move any more.
Hi, You possibly need to lubricate the capstan motor.
Jacques
