I'm looking for advice/discussion about lubricating the sintered bearings in a Beocord. I know that these were designed to be "lubricated for life", but I assume that the design life for these bearings passed many years ago.
Login to view image
The picture above is the bottom capstan bearing. This looks pretty good (to me) with very little wear.
Login to view image
The next picture is the wear surface of the upper capstan bearing. This has worn past the "porous" surface.
What is the best course of action:
- Re-lubricate the bearing using the clean and vacuum infuse methods. This seems like the right thing to do for the lower bearing, but I'm not sure about the upper bearing.
- Run the bearings "wet" and continually monitor/maintain to ensure that the bearing doesn't run dry. (i.e. the pores are closed so the bearing can't work as originally designed)
- Both 1 & 2
- A combination of 1-3 and swap the upper and lower bearings.
- Replace the bearings with news ones. Are the parts available?
- Something else?
