2 Beograms connect to Beosound 9000
Hello all, If any adaptor or cable to connect 2 beograms to Beosound 9000 at the same time so that I can use either one? I have Beogram 4500 and Beogram RX2 with pre-amp, both turntables are using Din 5 plug connect to Beosound 9000. Thank you for your help in advance.
Best Regards,
Peter
B&O used to make an aux expander with full 7-pin DIN inputs/outputs as shown below:
Login to view image
I don't know of any other 5/7 pin switching units.
The alternative is to use DIN to phono adaptors, and then get a switching box like this:
A more expensive remote controllable solution here:
Hi, I can find a 7 PIN AUX SPLITTER - DUAL AUX / TAPE INPUT SOCKETS from Sounds Heavenly. Is it the right adaptor in my case? Howver, unfortunately, he will not send to my place right now. Thanks.
Login to view image
Hi, thanks for your reminder. I think I need to find a switch box with 7 pin input instead.
Login to view image EDIT: And if you do remove the pins keep them somewhere very safe for future use (or future BeoGram users!)Location: Warwickshire, UK
Thank you so much for your advice!
No problem - happy to help!
A further thought - a while back I found this switch box which is designed for a different purpose:
Thank you so much for your effort!!!
