B&o 4002
Good afternoon my father has a turntable 4002 with a problem with the position sensor, is there someone not so far from italy that can fix the problem? Thanks in advance for your help   Veronica
Hi Veronica, Distance is relative... I can provide complete restorations to a considerable serious level whereby components and adjustments are made to achieve a really smooth working Beogram 4002 again. Just troubleshooting isn't always the best option especially when you want to avoid unnecessary transport for that "distance". Location: The Netherlands BR, Beobuddy.
