Beocentre 9300 & Beogram 3000
Would these work together well as a pair? (Beogram 3000 type 59)
thank you
simon
The BC9300 does not have built-in RIAA so in order to use the BG3000 you would have to add a phono/RIAA pre-amp.
I would look for a Beogram 3500/4500/6500 or 7000 with built in RIAA and datalink - thereby allowing you to control the turntable by remote. 3500/4500 are probably the best visual match with the BC9300.
This may help:
