Beogram 1000 cable
I restoring 3 Beogram 1000.  The original Signal cable has two Audio return shields and one Ground" "Chassis Ground" "Shield".  It looks like this cable is never available. What cable should i use and how to mount. thx Wolfgang
Assuming it does not have a phono preamp board, it depends on what input you are connecting to. If you are going to a DIN Phone input, you need a 5-pin DIN cable. If you are connecting to an RCA phono L/R jacks, you need a shielded pair plus a separate chassis ground wire.
