Beogram 1202
Dear all, my Name is Thomas and a write from Italy. I sadly have an issue with my beloved beogram 1202, the tonarm goes down far before the first groove of the Lp. Can someone please explain me how to regalate that? Thanks and have a nice day. Thomas
In the bottom cover there are two holes that adjust the set down point for 7” and 12” records. It is easiest to place it on a stand or supports so that you can watch the arm without having to constantly flip it. If your bottom does not have the holes then you will need to remove the 4 corner screws and remove it first. These eccentrics should be marked and are in the from of the cam gear.
Thank you Mark! I'll try later in the afternoon and hope not to cause any damage? Have a nice day!
