Beogram 2200 DIN plug problems.
Hi there.   I got this fine Beogram 2200 recordplayer. But the Din connector is bad - previous owner  did a bad job soldering and i want to re-solder the wires. But what wire goes to what pin? And how do i identify the right wire for the pin - and lastly - what about the shielding ?   I hope you can help - it would be much appreciated. regards from Denmark
Take a look at the 2200 schematic at https://beomanuals.com/manuals/Beogram/Beogram%202200/Bang-Olufsen-Beogram_2200-Schematic.pdf It provides all that detail.
Check this photo. Looking inside the 5-pin DIN Male plug. Center pin - Signal Ground Pin at 2 o'clock - Signal Right Pin at 4 o'clock - Signal Left Menahem Yachad Jerusalem
Electronics Technician in Jerusalem Israel. B&O fan for over 50 years.
