Beogram 4002 - end of play / stop problem
Hi All I now mostly have my bg4002 working- except the arm doesnt lift at end of record and then return as should -- i just stays next to the label. I have the suggestion of condor audio  re placing an extra wide black band at the plastic ruler thngo - but that doesnt work for me . I have noted that what i believe to be the end switch is not activated by the carriage as it stops short by several mm - should it be activated at end of record ? are there any suggestions to fix the problem? thanks in advance George
Which type of Beogram 4002? Martin
Hi Martin   It is a BG 4002/ 5221 the plastic ruler is the newer type which already has additional markings for the opto sensor .. please see photo for position of carriage with respect to the end switch- see it seems to stop short when stylus is at innermost of lead-out groove. I know the carriage activates the switch if stylus is up so it can go past the end of lead out groove- but if the stylus is down and switch is activated - does the stylus arm lift before returning across record - I am afraid it may destroy stylus by arm returning whilst stylus is still down.. thanks in advance for any advice George
Does the carriage hit on something? Cables near the transformer, perhaps? Transport safety screws losened? Martin
Hi Glitch Thanks for the  suggestion I have tried it and the arm IS raised when the end stop switch is triggered....so that at least is good. I estimate that i would need to insert a 5mm or so spacer to trigger the return at the correct point..:( I would has expected that the arm return is triggered optically rather than mechanically...so there may still be an issue though... Also the arm return has now happened a couple of times by itself  half way through a disk side....hmmm Thanks for your interest Cheers George
Hi Martin No the carraige doesnt seem to hit anything...when the stylus is in the end groove next to the label, the arm is still parallel to the sensor arm....and the carraige motor has stopped turning. If i move the stylus to over the label the motor will trigger again until the end stop is triggered. George
The end switch should not be reached at the end of playing a record. It should only be reached if no record is found. End of record is indeed optically sensed using the ruler. Has the main board been rebuilt with new capacitors, trimmers etc? Martin
Hi Martin Main board has not been rebuilt YET........ I have been trying to establish just what is needing attention as the person I bought it off could not get it going at all......... so far cleaning contacts / plugs etc has made the most difference .  at this point the only problem is the arm return  and a blown globe on the 45 speed dial... I suppose i am trying to avoid a pcb rebuild but think it is required in near future....it is nearly 50 yrs old.........and the lid is a mess with broken hinge points Cheers George
It will need a rebuild. They all do by now. New electrolytic capacitors. Replace like for like type-wise. New trimmers incl. adjusting. Martin
