- The detector arm does not function. I have confirmed the bulb works but does not turn on when pressing START. It is not being sent more than a few mv from the mainboard.
- The solenoid does not trigger with the up/down button (not sure if it would trigger from the detector arm). I have confirmed the switches are clean and are making contact. Lift/drop mechanism has been cleaned and lubricated, and solenoid triggers when I short IC4.
