Hi all,
I’m new to this forum. I bought a beautiful 4002 a year ago that is in great cosmetic condition and had not been used in many years. I went through the usual cleaning and lubricating process that Beolover suggests and now is functioning really well. However, I have two questions:
1. It functions perfectly other than it appears the sensor doesn’t detect if there is a record on the platter and will drop the needle regardless whether there is a record or not. The light on the sensor arm is working. I have borrowed an oscilloscope from a mate, however, I don’t know how to check the sensor voltage. Any help here would be greatly appreciated (I’m a furniture maker by trade - not an electrical engineer - so I’m not too familiar with electronics).
2. All the capacitors, relays and transistors are the originals. Is it worth preemptively replacing these? I would love to learn how to do this myself if there are any enthusiasts in Brisbane, Australia that would like to help me. I can offer a carton of beer or your favourite whisky ;) Alternatively, I could fashion a new solid timber trim (oak, walnut, rosewood, or teak) for a 400X as payment.
Thanks everyone!
Christian
Beogram 4002 - should I replace the capacitors
Welcome to the forum! You can find the service manual online which describes testing for the detection signal. If you are not comfortable with soldering and desoldering I would fine someone that is. While replacing caps and relays is called for as a general restoration strategy nothing is harmed to wait for a failure if it’s working fine. You can even live with the detection issue if it’s not simply an adjustment.
Thanks for the reply, Mark. I will take your advice.
Anyone Beogram enthusiasts here from Brisbane, Australia?
